Checking tie rods
Old Feb 17, 2011 | 05:38 AM
huge230's Avatar
Default Checking tie rods
Hey guys,
I know the typical process for checking tie rods but am in the process of rebuilding and pretty much am down to a bare shell. I am trying to decide of I need new tie rods, inner and outer, and wondering if there is anyway i can check them with no suspension and hence no wheels? Would pulling on the tie rod itself be enough to know if there was play in them?
Thanks in advance
Old Feb 17, 2011 | 11:40 AM
slowcivic2k's Avatar
Default Re: Checking tie rods
Originally Posted by huge230
Hey guys,
Thanks in advance
No, Inspecting tie rod ends can be done without the wheel, but you need a firm grip on the brake rotor (and thus the suspension) to feel any lash in the tie rods. The most correct procedure includes a "dry park" test.
This procedure requires that the wheels be on the front of the vehicle, and on the ground. Have an assistant wiggle the steering wheel while you hold onto the tie rod from underneath. (yes I know it is a tight fit.) Any slack requires replacement of the tie rod. This allows the full weight of the car to fight the steering, identifying joints that may not be loose on the next method.
The second method is preferred by most novice mechanics for its ease of inspection. It is the raised method. Raise the vehicle front end and support it. have an assistant shake each wheel, one at a time, while you monitor the tie rods on that side. Note any movement of the tie rod housing relative to the knuckle.
After the clearance test, if the joint passes, inspect the range of motion for the tie rods by turning the tie rods by hand left and right . If it is significantly difficult to turn, binds up, or has a "notch" worn into it where the joint feels very loose but is tight, suggest replacement.
Replacement is required if slack is present.
Replacement is suggested if the joint exhibits binding/notching during the range of movement test, or if the boot is compromised.
The inner tie rod is inspected the same way, but cannot be visually seen. The easiest way is to pull down on the tie rods with your hands. This is how you inspect the inner tie rod if the outer is loose, since pulling will force the outer tie rod into its socket further and remove most of the clearance. You will generally see the bellows boot notch in and out if the inner is loose.
Old Feb 17, 2011 | 02:16 PM
huge230's Avatar
Wow! Thank you
HondaLuv3r4Life
Honda Civic (2006 - 2015)
Oct 17, 2017 02:22 PM
mingbling96
Dec 11, 2004 04:07 PM
Gennady
Mar 10, 2002 06:17 PM
