crx bumpers on si hatch?
Old Feb 16, 2011 | 08:18 PM
dwils's Avatar
Default crx bumpers on si hatch?
anyone know if crx front and rear bumpers would fit on a 90 si hatch?
Old Feb 16, 2011 | 09:36 PM
killa69er's Avatar
Default Re: crx bumpers on si hatch?
from what I heard the CRX bumpers fit but they dont look good or line up correctly
Old Feb 16, 2011 | 10:20 PM
nineohnine's Avatar
i know u can do a CRX front bumper conversion. (ive looked into it) u have to use modified CRX fenders and bumper to make it look right. as far as the rear bumper i don't think so, cause it has the filler panel integrated into the bumper which im not sure is compatible with the hatchback.
to modify the CRX fenders to work you have to cut/weld the top half of a CRX fender to the bottom half of a hatchback fender.( you do this at the spot where the side molding would attach to the fenders)
here is a post that should help you and give you an idea of what it looks like
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/crx-front-end-civic-hatchback-2634739/#post42771318
here is another one just posted a few mins ago JDM CRX front end on hatch!
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/90-civic-si-crx-front-end%3B-2898340/
Old Feb 17, 2011 | 06:10 AM
stackedhouse's Avatar
I've heard that you don't have to cut and weld the crx fender but you'll have to use that black filler piece..
Old Feb 17, 2011 | 12:19 PM
Silverfoot88's Avatar
i heard that chuck norris did it by kicking the back of an EF hatch. jk. it's been done, but like ^^^^ said, it takes a bit of modification. i believe there's a build thread floating around of someone that swapped an entire crx front clip to a hatch and fit the rear bumper on. IMO the chuck noriss approach might be easier.
Old Feb 18, 2011 | 08:44 AM
dwils's Avatar
hahah sounds like its more of a pain than anything
Old Feb 18, 2011 | 09:23 AM
KINGVEM^^ED6's Avatar
x2^
2CAMSVTEC
16
Nov 2, 2021 12:00 PM
CBEengineering
47
Feb 6, 2009 02:40 AM
trojenman183
Mar 21, 2006 04:04 PM
bbrian
12
Apr 13, 2005 04:29 AM
whitehf
Oct 30, 2004 11:31 AM
