Timing belt change...what else?
Old Feb 16, 2011 | 05:36 PM
volsfan32119's Avatar
Default Timing belt change...what else?
I'm gonna be changing the timing belt on my 99 Honda Accord. I know it's a good idea to also change the water pump. Can someone please tell me what else I should change?
Old Feb 16, 2011 | 05:38 PM
shortlid's Avatar
Default Re: Timing belt change...what else?
Tensioner
Old Feb 16, 2011 | 05:51 PM
Tensioner...got it, thanks. Anything else?
Old Feb 16, 2011 | 06:10 PM
nicolaselias's Avatar
Loved
Community Favorite
Its usually convenient to change all belts at once so if your S-belt is bad, change that..
Also, as you have the timing cover off, if you have a leaking cam seal get that for sure..
Finally, what brand you buying and for how much? www.rockauto.com may be a cheap option for you.. or an advance auto online coupon (up to 40% off - pick up in store)
Old Feb 16, 2011 | 06:28 PM
Thanks man. Is there a crank seal also? I recently changed the alt belt and power steering belt so those are good. I usually buy all my parts from NAPA. I think the quality is better than Autozone and such.
Old Feb 16, 2011 | 06:56 PM
JohnSFerr2387's Avatar
SWITCH ALL BELTS
SWITCH SPARK PLUGS/WIRES AND VALVE COVER SEALS
FUEL FILTER
AIR FILTER
OIL CHANGE AND OIL FILTER
TRANNY FLUID AND TRANNY FILTER IF ITS AUTOMATIC
WATER PUMP
TENSIONER
FLUSH RADIATOR
CHECK FOR WORNED OUT RADIATOR HOSE
WHAT ARE YOU TRYING TO DO?
Old Feb 16, 2011 | 07:17 PM
Nicefeet's Avatar
Every seal behind the timing belt, even the oil pump o-ring.
Old Feb 17, 2011 | 03:30 AM
hondamark35's Avatar
you mean the oil pump outlet o-ring (between the back of the pump and the block) or the rear balance shaft o-ring (between the rear balance shaft housing and front of the oil pump; more common to be replaced)
Old Feb 17, 2011 | 05:22 AM
Thanks for the tips guys. My car has 160,000 so I figured I've pushed my luck far enough with the original timing belt!
Old Feb 17, 2011 | 06:30 PM
Loved
Community Favorite
Wow... Very very brave..
After the tensioner failed and the belt broke on my dads Mitsubishi Pajero (foreign Montero) and bent some of the tapets, we decided to check on the accord belt..
At about 145,000 miles my belt looked like it was ready to burst! Changed it and the tensioner, i think we went with Gates
Old Feb 18, 2011 | 10:26 AM
Cool, thanks man!
Old Feb 18, 2011 | 08:24 PM
nus_dogg's Avatar
You can do what most had mentioned; don't forget to make sure that you have the front balancer shaft oil seal retainer because this was one of the recall Honda had since the seal would push fall out and cause oil leaking everywhere.
Old Feb 21, 2011 | 10:50 AM
Thanks for the info and diagram nus-dogg!
ezol
Acura TL, RL & ZDX
11
Sep 21, 2010 08:29 AM
whiteboy-dc4
Feb 3, 2010 11:52 AM
professorman
Mar 27, 2009 02:02 PM
shepworldwide
Acura TL, RL & ZDX
Aug 15, 2006 07:37 AM
hkboy87
Jan 15, 2006 01:39 PM
