Sway bar and shift linkage issue
My shift linkage is hitting my sway bar, making it hard to put the car in first and second gear. I have a Sir front sway bar with a hasport linkage. Has anyone every had a problem like this?
same here never seen this b4
maybe try and change endlinks to raise or lower the sway up or down a bit?
whaaa?? the sway bar is totally out of the way of the shift rod on the trans...maybe exhaust would be in the way buuut how the EFFF would the sway bar be?
also forgot to ask pix??
and is the sway mounted on upper or lower of the control arms?
Look at the mounting of the sway bar endlinks where I show the ITR endlinks and bar. See how they're coming up from underneath? That will give you additional clearance at the back side by the shift linkage.
WideBodyFEELZ
10
Jul 13, 2015 02:03 PM
WideBodyFEELZ
Suspension & Brakes
14
