1989 Honda CRX DX auto to manual conversion
Hey H-T,
I have a 89 CRX DX with a sohc ZC motor that's automatic. I want to do a 5 speed conversion but I don't know what I need.
I have a 5 speed transmission with shift linkage and the other bar(i forgot what its called) on it. and also a DX 5 speed ecu.
I've read online that im going to need the pedal assembly, but do I have to get it off of another dx or can i get a hf or si one?
also i know im going to need a gauge cluster, clutch, flywheel, and pressure plate. What else do I need? Is there a write up? I've searched but I've got some bogus threads not even about the conversion.
THanks!
THanks!
Please search this is covered quite often.
What are you using as search terms? I do think the FAQ has a write up on this still.
I would advise against a STD(cx)/HF pedal set as they are thinner and weaker. A few members myself included have snapped them.
You do not really need the gauge cluster, if money is tight or you plan on running an aftermarket tachometer.
I know there's a CRX DX from the junk yard that is manual. So would that be perfect for the pedals? I'm thinking to just get a d16z6 swap and throw it in all at once.
Motor and tranny from pick n pull is about 400 something out the door.
Yeah money is tight but I'm waiting on my tax return to get about 400-500 to spend on a new motor....
x1racer
Oct 15, 2004 08:40 AM
crxforum
17
Nov 29, 2002 11:30 AM
froggie3kb
Jul 17, 2002 04:16 AM
Downey
Mar 20, 2002 09:16 AM
