LA Anyone looking for a cheap turbocharged k24 ek civic hatch?
Year
1996
Make and model
HONDA CIVIC CX HATCH
VIN
2HGEJ6328TH120892
Mileage
~140K
Transmission type
Manual
Title status
REconstruction- THEFT
Modifications
Yes
Additional information and mods
1996 HONDA CIVIC CX HATCHBACK W/99-00 FRONT END.
new paint.....championship white
~140K MILES ON CHASIS
Motor:
2.4 K24a2 LongBlock (2004 tsx) less than 2000 miles on motor (from factory not rebuilt)
K20a2 rsx type s transmission
- REV HARD turbo kit: tial 38mm wastegate, vortec bov, 60 trim precision turbo (rebuilt less 1000 miles on it), sparco intercooler
-1000cc Dynamic injectors
-Professionally Tuned at ProTech in Austin, Texas
- custom 2.5" exhaust with dump tube
RBC Intake Manifold
K20a2 Throttle Body
Hondata Intake Manifold Gasket
K20a2 ECU with Hondata K-Pro with boost option, 5000rpm launch control, and 8200 rev limit
Intake Cam Gear (VTC) Machining to 45 degrees
Civic Si Idler Pulley setup
ACT 6 Puck Sprung Clutch kit/ ACT 12 lb flywheel
Hasport EKK2 Engine Mount kit
EG Cross Member/LCA assembly
C&R acura rsx type s Radiator w/ slim fan
Hasport Radiator Adaptor
Hybrid-Racing Harness
K20a2 Shifter Cables
K20a2 Axles/halfshaft
CircuitWorx 36mm Hubs
400 whp custom cv joints
Custom SS braided Fuel lines
Aeromotive FPR w/ pressure gauge
Aeromotive inline Fuel filter
Karcept shifter mounting kit
Karcept throttle body adaptor
Suja1 SS braided clutch line
Golden Eagle Red Fuel Rail
K20a2 Wideband primary o2 sensor
Walbro 255 fuel pump
Suspension:
15 x 8 949 phantom chrome rims (weigh less than 12lbs each)
BF Drag radial up front and Azenias in the rear
Shunk2 rear brace bar
K-Sport Fully adjustable coilovers
K-sport LCA s
-crossed drilled rotors (all 4 corners)
-sparco seat beat harness with sparco seat belts
Exterior:
99-00 Front End conversion
99-00 Si Lip and Grill
Spoon Replica Mirrors
-JDM rear spolier
-JDM front fog lights
-eyebrows
-tinted windows
-JDM headlights with 8K HIDS
Interior:
Sparco Tuner Steering wheel with removable kit
Tenzo red racing selts with sparco seat belts selt bealts matching back and door panel...alll red...Looks great!
-autometer boost, oil, volt, water temp,& aem wide band
-Full interior
-jdm carbon fiber airbag cover
custom stereo system: pioneer cd player, bluapkant 5.24 and 6x9
The car has no problems. It just sets in the gargage. The car is scary fast with 330whp and 280lbs/tor on tap the quarter mile is over in a blink of an eye if you can control it. The car is tuned at 12psi with a plenty of fuel left and boost to toy with. The obly thing I recommend would be lsd and some driving lesson. Here is a link with some up to date pics and a somewhat build on the car. the first 9,000 cash takes it home. Any questions and I can be reached at 318-572-9713. I'm only selling because I own seven cars, m3, g35, ek coupe, integra, two beetles and this hatch and I can only drive 4 cars due to my insurance policy so I am cleaning house. I have put less than a thousand miles on this car in the two years of me owning it.
http://www.hondamarketplace.com/show....php?t=2591571
1996
Make and model
VIN
2HGEJ6328TH120892
Mileage
~140K
Transmission type
Manual
Title status
Modifications
Yes
Motor:
RBC Intake Manifold
K20a2 Throttle Body
Suspension:
K-sport LCA s
Exterior:
-JDM rear spolier
-eyebrows
-tinted windows
Interior:
-Full interior
ok with the overwhelming email and pms...the best I can do is 8k, but since I own a shop I will remove a couple items.
rims...you will have to supply your own
interior...I will supply factory civic seats and door panels...there will be no back seat included, factory seat belts will be included no seat harness
gauges: I will remove the aem wideband and boost gauge and the gauge bezel...I will replace the bexel with an oem
hid's- i will replace with factory bulbs
sparco steering wheel-rplace with a factory steering wheel
stereo cd player and speakers--nothing
So basically tou get the shell, motor, and suspension, no cosmetic goodies. That is the best I can do.
underb00steg6
Aug 24, 2011 01:16 AM
bump for a turbo k24 in tha 3 states.
