K24a4 Block / K20z3 Head, piston and rod question
Old Feb 16, 2011 | 02:03 AM
Sp00ner's Avatar
Default K24a4 Block / K20z3 Head, piston and rod question
For the setup mentioned, K24a4 Block / K20z3 Head, would buying after market TSX rods and pistons work for the clearance problem and allow that set up to work?
Old Feb 16, 2011 | 11:46 AM
Sp00ner's Avatar
Default Re: K24a4 Block / K20z3 Head, piston and rod question
K24A4
Found in:
2003-2005 Honda Accord(USDM), 2003-2006 Honda Element
Displacement: 2,354 cc (143.6 cu in)
Bore and Stroke: 87 mm x 99 mm (3.43 x 3.90 inches)
Compression: 9.7:1
K20Z3
Found in:
2006-2011 Honda Civic Si (FG2 - Coupe & FA5 - Sedan), 2007-2010 Acura CSX Type-S
Displacement : 1,998 cc (121.9 cu in)
Bore and Stroke: 86 mm x 86 mm
Compression : 11:1
maxtierney
Honda Civic (2001 - 2005)
Jan 31, 2013 08:32 PM
aschrock
Mar 17, 2012 09:51 PM
CHRIS29
Apr 12, 2011 08:15 AM
nggrmxn
May 24, 2008 07:21 AM
BeavisB16
Feb 22, 2003 12:28 PM
