NX nitrous kit w/ purge, H22a Euro R pistons and rods, EG radiators, ecu's, and more!
Nitrous express wet system with purge kit, and fuel line with t fitting that will bolt on. Needs bottle and fogger (cheap and easy to find) $125
2001 H22a Euro R pistons (p5p) and rods. 1 piston is damaged. This motor ran like a champ until clogged injector caused damage. Was making 244whp and 166 tq. Running 11.54@116.5 mph all motor on a bone stock bottom end. SOLD
EG/Ek aluminum OEM radiator with fan and lower B series radiator hose $50 firm
Not working Ob0 pr3 and pwo ecu's. Can be repaired. $20 each
P14 ecu works perfect! SOLD!!
99-00 civic Si P2t ecu works perfect $125
P75 ecu works perfect SOLD
88-91 civic/crx si clutch cable $20
ac auto technik H series scatter shield. Pass tech inspection and stay safe! SOLD
99 Gsr intake arm with air box and filter. Fits in Eg and EKs too. SOLD
2000 H22a shift linkage brand new from honda. Payed $289 Selling for only $100!
2000 civic si clutch master cylinder with reservoir and hose $50
B20B valve cover SOLD
88-91 civic/crx si battery tray $20
Shop oil drain. Can transfer oil with air feed. $100
92-95 civic front brake calipers brand new left and right. Never used $50
2000 civic Si OEM A/C kit with condenser $140
Fuse boxes for Da, eg etc... $10 each
Dc5 shifter box $60
Let me know if you have any questions. Even if you don't need anything. Please spread the word to your friends. Thanks for looking!
Dc5 shifter box $60
lmao at the oil container.... i wonder if they will let me take that in @ autozone/pepboys LOL
This is obviously for shop use. I figured I would add it on here because people with shops frequent the classifieds.
