lobes on intake and exhuast?
Old Feb 15, 2011 | 05:20 PM
accordmatt's Avatar
Default lobes on intake and exhuast?
ok now lm almost positive about this but wanna make sure. ive seen a few different ways but both on dohc. ok so with arrows at tdc for #1 should both intake and exhuast valves be pushed down by lobes? or just one either intake and exhuast and other not pushed down? because with both my arrows pointing up at tdc intake #3 valves are open (pressed down by lobes) and #2 exhaust valves are open(pressed down by lobes) is this correct?
and to check valve lash both intake and exhuast side on that particular cylinder need to be pressed down to check right?
Old Feb 15, 2011 | 08:01 PM
Enzo15's Avatar
Default Re: lobes on intake and exhuast?
To check lash you want the valves to be closed, so you do not want the lobes to connect. I recommend getting the helms manual if you dont already have it. They are free online.
Old Feb 16, 2011 | 06:32 PM
mafia's Avatar
X2
USE A HELMS!!!!! Or you will have very loud ticking noise.
94lsrhd
Jun 13, 2009 05:55 PM
sup3rd
Nov 26, 2007 06:30 PM
Civicr2gs5
May 18, 2004 06:44 PM
senpai
Jul 25, 2003 07:49 AM
jdm169
Jan 24, 2003 05:36 PM
