oil leak worsens to 1/2qt every 2-3days...
Old Feb 15, 2011 | 02:49 PM
blacktibby07's Avatar
Default oil leak worsens to 1/2qt every 2-3days...
as subject says...
i cleaned entire engine area and pan with degreaser on sunday, today i got back under there and oil is coming from 2 locations, theres a leak at oil pan gasket right at where half moon meets at crank pulley...
then on other side a much worse leak where tranny hooks up to engine at half moon point once again...
is this where oil pan gaskets leak first or could it be something else?
Old Feb 15, 2011 | 06:21 PM
Default Re: oil leak worsens to 1/2qt every 2-3days...
heres some pics, crank pulley side...
tranny engine side...
and from in front of tranny engine... um i noticed this bolt wrapped in electrical tape about an inch out???? any ideas lol
Old Feb 15, 2011 | 06:33 PM
Former User's Avatar
Any visible leaks higher up on the engine (VTEC solenoid, distributor, valve cover gasket)? If not and you are lucky, replacing the oil pan gasket will fix the leak. If you are unlucky, the front and rear main seals and/or cam seal are leaking.
Old Feb 16, 2011 | 01:52 AM
nope nothin up top wish i had vtec haha...
ummm...
can i pull up the car on ramps to remove oil pan?
is there enough room to get get exhaust manifold out of the way on top of them?
Old Feb 16, 2011 | 06:40 AM
nickdmai1234's Avatar
Oh wow, I have the same problem in my car. im about to go take it to my friends shop. Ill let you know what he says. my leak is identical.
Old Feb 16, 2011 | 08:54 AM
DCRB's Avatar
ummm...
yes you can pull it on ramps, unless you have an aftermarket one piece header just unbolt the down pipe from your manifold and from your cat, then drain the oil from ur engine (important to avoid a biiig mess) then drop the pan.
Old Feb 16, 2011 | 11:45 AM
blowededup's Avatar
Oil pan gasket, rear main seal, distributor O-ring, camshaft seal are the first 4 things that come to my mind.
Honda-Tree
Honda CR-V & Element
Apr 16, 2014 06:37 AM
JDMjdawg
Sep 28, 2013 06:06 AM
Ralph3991
Jan 11, 2013 07:18 PM
immalooser
Sep 25, 2009 08:05 AM
G2_Fella
13
Jul 16, 2005 06:53 AM
