b16 swap-clutch very hard
Old Feb 15, 2011 | 01:31 PM
mr2pac's Avatar
Icon6 b16 swap-clutch very hard
i have a b16 swap in my ef. it runs great but the clutch pedal is hard to press.the tranny is a hydro but have the hasport hydro to cable convestion kit. ive already snapped two wires. ive adjusted the slacker nut on the cable and the pedal nut,but cant make it soft.i have a wire from a 94 acura in there now.
need help figuring how to make this a lil bit easier on the leg.
any help would be great.
p.s. bracket is on the right way.
cable is over the motor so there is no sharp bends
Old Feb 15, 2011 | 10:24 PM
RTUNED BUILT's Avatar
Default Re: b16 swap-clutch very hard
first what type of clutch and pressure plate do u have.. second make sure u adjust the cable not too tight leave it bit loose, sum people like the sensitive clutch feel, and adjust the cable too tight.
Old Feb 15, 2011 | 11:23 PM
hatchet_honda's Avatar
wire? as in clutch cable? if youve broken 2 cables theeen you have some clutch issues. pressure plat perhaps. it shouldnt be that hard to disengage
hondaciviceg4dr
Mar 25, 2015 10:28 AM
user 72830283
40
Sep 22, 2005 12:06 PM
InJ3cted
May 24, 2005 02:16 PM
coot_er
May 24, 2004 12:12 PM
