How to get the head off my zc
Old Sep 25, 2002 | 01:41 PM
cr-x si's Avatar
Default How to get the head off my zc
I want to take the head of my zc so I can check out the pistons and valves. But I am not sure how. What all do I have to take off of the engine? Do I have to take out the cams? I don't have any air tools or a torque wrench. can i still do it
Old Sep 25, 2002 | 01:46 PM
Malgerus's Avatar
Default Re: How to get the head off my zc (cr-x si)
Not without a torque wrench... How did you expect to torque everything to spec??? You can do it without air tools, but you'll need a long ratchet or a big bar to get the headbolts off. Why do you want to look at the pistons? Shine a flashlight through the spark plug holes... No but seriously, unless there is a problem, don't bother. Pick up a manual though that tells you how to do all this.
Old Sep 25, 2002 | 01:48 PM
cr-x si's Avatar
Default Re: How to get the head off my zc (89_Y_49RIP)
well i just got the zc the other day an i need to check everything over and make sure it is good befor i install it.
Old Sep 25, 2002 | 03:44 PM
altoid's Avatar
you should get their word for that. Then if anything is wrong, go return it. From what i understand the dohc heads need the cams to be removed before the head is taken off, but not with the sohc
beatthisspeed69
Jul 18, 2007 03:49 PM
White91EF
Dec 31, 2006 11:31 PM
CRX_RUS2
Nov 26, 2004 12:52 AM
second edition
Jun 18, 2004 09:14 PM
SecretMan
Mar 6, 2003 05:20 PM
