jg built gsr
Old Feb 14, 2011 | 05:16 PM
turbozc03's Avatar
Default jg built gsr
Ok I will try to explain this as short as possible.
I bought a kg built Gsr from a friend. The engine ran perfect and Vtec worked fine. I have a 97 hatch that had a y8 swap, it ran and Vtec worked fine.. the car is a cx and I used a ex harness.
I installed the engine and now when Vtec pops it hits a wall, sounds like some sort of ignition cut. The head is built with oversized valves cnc ported, springs ect. It has skunk2 pro 3 turbo cams. Vtec pressure switch is disabled, ( even tho oil pressure is fine) I have changed the sel. with one off a running engine. I have also changed the dizzy, checked the continuity in the wire... has good connection. Timing is dead on ect. The car runs fine on low cam and if I in plug the Vtec sel. it runs like ***......
I would like some help with this guy so please post any and all ideas.
Thanks.
Old Feb 14, 2011 | 05:49 PM
mouab18c1's Avatar
Default Re: jg built gsr
Originally Posted by turbozc03
Timing is dead on ect. The car runs fine on low cam and if I in plug the Vtec sel. it runs good. Just when its plugged in it hits a wall.....
I can't even understand you!
Old Feb 14, 2011 | 06:05 PM
turbozc03's Avatar
Sorry. Ment to say if its plugged in it hits a wall right when Vtec is suppose to pop. If its unplugged it runs fine on low cam.
If u can't understand sorry.
Old Feb 14, 2011 | 07:33 PM
blown_ss's Avatar
what ecu are you running? is it tuned?
Old Feb 14, 2011 | 08:16 PM
mark@silbernage's Avatar
Ideas to try:
a) fuel - is it possible the fuel pump/filter can't deliver enough?
b) electrical - with the new wiring harness, possibly a ground problem?
c) cam timing - any chance it slipped a tooth (etc) during install?
I'm sure you'll figure it out! Sounds like a nice engine.
Mark
Old Feb 14, 2011 | 10:01 PM
turbozc03's Avatar
Originally Posted by mark@silbernage
Ideas to try:
Mark
Chipped p28
Yes on chrome gold, and the guy that tuned in my buddies car is the same guy that tuned it in mine. This guy knows his stuff and is a very respected tuner. He also has never heard of this problem. Errrrrr
A. I changed it like a year ago....the thing is that it runs fine to 10000 on low cam
B. I am using the same one I used on my supercharged y8 and I has added a extra ground strap...
C. I have checked it time after time and its dead on.
These are 3 good points... thanks.
Would not having the cams degreed cause this? Also when I have the Vtec sel. unplugged and have a test light hooked up, and I rev it up. The light comes on and is bright. If I have the sel. Plugged in and the test light hooked up when Vtec pops the light is dim like it has a really bad draw it the system. I just don't know. This is very frustrating. :-(
Also I don't know if this would matter at all, but I am running FIC 1350CC Fuel injectors
Old Feb 14, 2011 | 10:21 PM
Ok, how about this... either short in vtec solenoid, or wire, and it's drawing too much current and dropping voltage. When voltage drops, fuel pressure drops along with (possibly) spark voltage? Wonder if it could cause short pulses on the injectors too (delayed open, shorter 'on time', etc)?
Now, alternative to short is poor ground - i.e. it would have similar effects (low voltage) but without the excess current draw. Forget either of the chassis to MT or Engine ground straps?
Got a spare vtec solenoid handy?
Put a voltmeter on the system and tell us what happens when vtec hits? Be sure and check directly across the battery, but also at the vtec sol itself and whatever ground it's using..
Thx - Mark
Old Feb 14, 2011 | 10:28 PM
turbozc03's Avatar
Thx - Mark
K I will do that ASAP. I have the cams out right this sec cause I am gonna throw in some stock ones and see if that does anything. But I will post my findings on that when I get a chance. Thanks mark
Old Feb 14, 2011 | 10:33 PM
turbozc03's Avatar
Just a couple of pics
Old Feb 14, 2011 | 11:57 PM
really nice!
Old Feb 15, 2011 | 12:55 AM
megawrench's Avatar
indeed nice, yes i would have to agree it sounds electrical
Old Feb 15, 2011 | 02:21 AM
turbozc03's Avatar
Thanks guys. And ya, I am looking for a harness. My only problem is that my previous engine ran fine and Vtec worked great.
Old Feb 15, 2011 | 03:24 PM
turbozc03's Avatar
Bump still doing it
Old Feb 19, 2011 | 06:52 AM
turbozc03's Avatar
Adj valve lash, changed harness and Vtec sel, have great oil pressure, and still no Vtec. I can't believe none else has had this problem. Someone please help.
Old Feb 19, 2011 | 09:30 AM
mouab18c1's Avatar
Try another ECU!
Old Feb 19, 2011 | 06:29 PM
Were you able to take voltage measurements mentioned earlier?
Also, in a different recent thread someone had an IAC acting up that seemed to create similar issues to yours - he didn't know if it was IAC or some kind of stuck valve in the EVAP canister. You might block 'em off for a quick test and see how it behaves at VTEC?
Change one thing at a time.. ; ' )
Old Feb 19, 2011 | 07:37 PM
1998GsRIntegra's Avatar
10000rpm is up there. Car looks clean.
Old Feb 20, 2011 | 05:10 AM
turbozc03's Avatar
Originally Posted by mouab18c1
Try another ECU!
One step ahead of ya. Did that, and it didn't help.
Old Feb 20, 2011 | 05:15 AM
turbozc03's Avatar
Yep voltage is great.... I do have another iacv, so I will for sure try that. Evap is already gone.
I also have done a lot of reading on theses skunk2 pro 3's and people having issues. So I am changing back to stock cams tomorrow, and see what happens. Thanks for the help
Old Feb 20, 2011 | 11:59 AM
turbozc03's Avatar
Well guys I figured it out. Woohoo. Took the skunk2 pro 3's out and put in some stock ones. Boom now I just need to get the pro 3's and the cam gears degreed and I can run them. Thanks for input people
Old Feb 20, 2011 | 03:05 PM
mouab18c1's Avatar
You were running pro 3's at 0'0?
Old Feb 20, 2011 | 05:39 PM
turbozc03's Avatar
Yes sir not good?
Old Feb 20, 2011 | 06:03 PM
2ltrgsr's Avatar
even pro1's need to be degreed properly....i'm scared to see what else is done on this car
Old Feb 20, 2011 | 07:21 PM
mouab18c1's Avatar
The thing I don't understand is according to your OP the motor ran fine in your buddies car. How does it not work after you swapped chassis? Are you sure it was even running good when your buddy had it?
Old Feb 20, 2011 | 07:45 PM
turbozc03's Avatar
Wow thAnks man, I got this engine already built and it ran just fine in my buddies car. Thanks for the low blow!
