Help. DPFI to MPFI conversion
Old Sep 25, 2002 | 01:08 PM
CivicHB91's Avatar
Default Help. DPFI to MPFI conversion
Need some help with DPFI to MPFI conversion. I have a stock 91 hb.
Old Sep 25, 2002 | 01:17 PM
Soled Out's Avatar
Default Re: Help. DPFI to MPFI conversion (CivicHB91)
http://tech.hybridgarage.com/tech/4g...-zc-wiring.htm
and try doing a search on here
Old Sep 25, 2002 | 01:19 PM
DevineCRX's Avatar
What do you need help with?? Take a look at http://tech.hybridgarage.com/tech/4g...-zc-wiring.htm
[Modified by DevineCRX, 10:20 PM 9/25/2002]
Old Sep 25, 2002 | 05:16 PM
Hayasa15's Avatar
Default Re: Help. DPFI to MPFI conversion (DevineCRX)
do you have all the parts? if not, i have them for sale im me.
Old Sep 25, 2002 | 05:58 PM
joshwhe's Avatar
Default Re: Help. DPFI to MPFI conversion (Hayasa15)
hey how much do you want for the parts?
Old Sep 25, 2002 | 06:21 PM
CivicHB91's Avatar
Basically need help from the beginning to end. This is my first time doing this. I need to know what parts I need and "how to" list.
Old Sep 25, 2002 | 06:42 PM
b16awarrior's Avatar
New User
Si intake manifold, with all sensors intake air temperature, IACV,TPS, etc.
Fuel rail, fuel injectors, injector resistor, PM6 ECU
Old Sep 25, 2002 | 07:01 PM
CivicHB91's Avatar
Default Re: Help. DPFI to MPFI conversion (b16awarrior)
thanks
Old Sep 25, 2002 | 07:10 PM
4gvtec's Avatar
you forgot the pm6 distributer.
Old Sep 25, 2002 | 08:11 PM
New User
Default Re: Help. DPFI to MPFI conversion (4gvtec)
My bad.
Old Sep 25, 2002 | 08:48 PM
Louie B.'s Avatar
not to mention:
Si wiring harness (for the plugs)
Si throtle cable (not absolutely neccissary, but makes the install cleaner)
NEW Intake manifold gasket (plus new gaskets for any parts that have been removed from the intake mani)
If the mani has been sitting for a while, you may need new injector seals (mine did)
You'll also need to modify / replace your air cleaner / intake tube (now's the time for a CAI)
and lots of time and patience. The pros may be able to knock this swap out in a couple of hours, but novices need to be prepared to have your car down for a couple of days (mine was down for over a week due to bad parts that needed to be replaced)
[Modified by thumpu77, 9:51 PM 9/25/2002]
EKDee
Mar 13, 2008 09:33 PM
project midnight
Nov 19, 2006 05:49 PM
JdM_RACeR07
Oct 11, 2006 08:50 AM
175Shot4Door
Aug 6, 2006 12:17 PM
mikecivichb
Feb 29, 2004 07:24 PM
