How many miles can u go on empty?!?!
Old Feb 14, 2011 | 09:47 AM
elliascool's Avatar
Default How many miles can u go on empty?!?!
im my 97 accord 4dr auto ..... i would always go a few miles after the yellow gas light would go on but since i havnt drove it in a long time i forgot .... is there an exact number of miles u can go with the yellow gas light on? or the point where u cant start your car anymore ?!?!?!
Old Feb 14, 2011 | 09:57 AM
quickster's Avatar
Default Re: How many miles can u go on empty?!?!
I've driven 40miles once, but I wouldn't push it past 50. I never let my gas get below a half tank though if I can help it. The deposits at the bottom are most likely abrasive to your cars fuel system. It also would depend on how hard you are on the gas pedal. When I drove 40 miles it was on the freeway.
361 accord's Avatar
30 miles-because it will go further but then the engine shuts off when you brake there is so little gas
Old Feb 15, 2011 | 01:37 PM
kd97accord's Avatar
last summer, when the light stayed steady on, i went just over 100kms
Old Feb 15, 2011 | 02:31 PM
accordmatt's Avatar
l think car will go 45 miles but suppose to cut off 3 times before ur done. and its not a good idea at all. all the dirt and junk in bottom of tank will clog injectors or possibly worse
Old Feb 15, 2011 | 08:49 PM
holmesnmanny's Avatar
I'll guess 0 miles ? I might be wrong though.
Old Feb 15, 2011 | 08:50 PM
Seriously, though, I ran out of gas around 55 miles after the light came on once before but it was weird because it seemed like my clutch was going out since it only bogged when I tried to switch. It was weird.
Old Feb 16, 2011 | 03:28 PM
poorman212's Avatar
My two cents. When the light comes on, fill it up. Then since you know how much the tank holds and how much you put in, you know how much gas is left....then use your gas milage (avg per tank)...and there you go. Every fuel sender will be a little different as to when the light comes one.
Old Feb 16, 2011 | 05:24 PM
JohnSFerr2387's Avatar
DONT TRY IT. IT ISN'T GOOD FOR THE MOTOR. ONCE YOUR HAVE A QUARTER OF A TANK FILL IT UP. NO ONE SHOULD EVER DRIVE ON SUCH LOW GASOLINE. IT MESSES UP YOUR FUEL SYSTEM
Old Feb 18, 2011 | 11:34 AM
darkninja11's Avatar
Isnt that what a fuel filter is for? correct me if i'm wrong.
Old Feb 18, 2011 | 11:36 AM
elliascool's Avatar
yea true but over time it needs to be cleaned/replaced
Old Feb 18, 2011 | 08:02 PM
nus_dogg's Avatar
Keep doing it, and you'll be buying a new fuel pump soon. Doing it yourself would be a PITA cause you'll need to drop the gas tank to get to the pump or pay a shop which will cost you a leg and a arm to get it replace. Fuel keeps the Fuel Pump cool liked stated above.
Running it til the light comes on will cause the pump to run hot which wears it out quick!
Old Feb 19, 2011 | 09:05 PM
elliascool's Avatar
ok didnt know that thanx but dropping the gas tank is easy as heck tho so ....
Old Feb 19, 2011 | 09:34 PM
nus_dogg's Avatar
It's not too hard but when the welded nut that holds the two bolts for the gas tank strap turns along with the bolt when loosening it, that will tell you how hard it is when you have to drop the rear sub-frame to get the tank down. It's not easy where there's snow because those bolts underneath the car are rusted to ****.
Old Feb 19, 2011 | 09:47 PM
ddh052286's Avatar
You can go 0 miles on an empty tank.
Old Feb 20, 2011 | 12:15 PM
elliascool's Avatar
yea rusted bolts would make it impossible ...
Old Oct 20, 2011 | 11:49 PM
Broke_not_built's Avatar
Drop the gas tank? O_o never took your backseat out or what lol
w4kj4k
Dec 13, 2008 08:23 PM
daonei
Nov 19, 2007 04:18 PM
Spoogen_1
Jun 3, 2007 09:56 AM
S2Ktien
Honda S2000
42
Jan 27, 2006 08:42 PM
DJ_CARY
11
Aug 10, 2005 06:30 AM
