Is there a way to adjust windshield wiper clearance?
not so much adjust as replace the worn linkages which are the likely culprit.
you can "clock" the wiper arms on the studs that they bolt to. just unbolt, lift and bolt down at a different angle. this will adjust the total sweep either left or right. new linkages will cure sloppy, lose wipers.
There is a plastic "bushing" that is in the wiper arm components, these get worn out over time and cause unnecessary play in the arms which causes them to hit each other or go past the windshield.
I'll try to find a diagram of the part.
numbers 11 and 12
brewerkz
Jul 6, 2016 03:23 PM
myownreality
Feb 9, 2013 10:43 PM
ophdehEEzY
Sep 8, 2003 04:53 PM
