What Strut forks work with the EF?
Old Feb 13, 2011 | 04:43 PM
91GEDHATCH's Avatar
Default What Strut forks work with the EF?
I was changing my struts out today and broke the head off the rusted bolt that hold the fork onto the strut. So Im looking for a replacement and can't find anything around. Just wondering, are there any that are interchangeable using Tokico blues for an EF?
I can't find them for sale anywhere and not too many show up in the scrap yards. Thanks.
Old Feb 13, 2011 | 05:04 PM
bEEsKnEEs's Avatar
Default Re: What Strut forks work with the EF?
ef or da forks will work. eg and dc forks have a wider inner diameter and will work if you wanna run eg shocks
Old Feb 13, 2011 | 06:20 PM
91GEDHATCH's Avatar
Okay thanks.
Old Feb 13, 2011 | 07:37 PM
night's Avatar
Front? stock/oem shocks? While you have that apart would you do me a huge favor please? I really need some measurements to confirm some stuff.
-inside width of the fork at the bolt holes/shock bushing
-From the bolt hole center to the top of the fork (height)
-With the shock in the fork, the bolt hole center to the top of the spring perch. not including the studs (total fork + shock length)
-shock diameter (inside diameter of the fork mount)
and then I might even need to buy those forks from you if you don't reuse them.
Thategdude
Suspension & Brakes
Dec 5, 2016 11:41 PM
724chris
Jan 10, 2010 06:40 PM
Colin
Dec 1, 2008 06:58 AM
t57b18
Oct 2, 2006 07:31 PM
89dohcEF
Nov 8, 2003 11:58 AM
