Source for s2000 male engine loom connectors....
Hi folks,
my AE86 is getting wired up at the moment and my donor engine came with a few broken connectors on the engine harness. I need to try and get the male ends of the connectors from the engine harness.
I think I need (check again tomorrow)
The exhaust cam sensor male connector (back left of cam cover)
The vtec solenoid/sensor male connector
The water/oil temp sensor male connector
Anyone help or point me in the direction of a wiring components place that may have em ?
Cheers
Ian.
Cheers
Ian.
Yeah - we are going to try some breakers yards
I just wondered if anyone had been making up engine looms to run different ECU's and they had found a source for getting brand new male connectors to work with the various senders and sensors that are already on the engine. I think HALTEC may do their own s2000 looms for their ECU's so there must be a place to get them from (unless they use a small bridge loom onto the standard car engine harness)
I'll keep looking but if anyone comes up with anything I'd appreciate it.
You do have this option as well......
http://www.hondaautomotiveparts.com/...ECTOR+(FR.)+(2)
I'm sure there's a place to purchase in UK as well?
*edit* Bleh, looks like those are just some of the more generic ones, here's the whole harness for $240 new
http://www.hondaautomotiveparts.com/...5=WIRE+HARNESS
Still drawing a bit of a blank on these guys - if anyone comes across a busted up loom we can cut the connectors off give us a shout - F20C not F22C (although I'm sure most of the sensors and connectors will be the same).
f20cmx5
Engine Management and Tuning
Oct 2, 2012 11:33 AM
CWESTINAP1
Jun 5, 2005 07:25 PM
