Transmission question
Old Feb 13, 2011 | 04:38 AM
b00stedOne's Avatar
Default Transmission question
Hey. This is my first time opening up a tranny myself. Its and LS hydro tranny and I am installing an mfactory lsd. My question is, can I use the ring gear (i think its called a ring gear. the big gear that bolds to the diff) from and sir instead of the ls to get a little shorter gearing? I already have the ring gear, but do i have to swap out anything else to make it work?
Thanks in advance.
Old Feb 13, 2011 | 07:58 AM
b00stedOne's Avatar
Default Re: Transmission question
anyone?
i updated the info to try to explain a bit better
Old Feb 13, 2011 | 08:09 AM
Metrospeed's Avatar
Thanks in advance.
You will have to swap out the counter shaft with the ring gear.
Old Feb 13, 2011 | 08:14 AM
b00stedOne's Avatar
ok thanks man. in that case, i guess i wont be using the sir one because i dont have the counter shaft.
jarhead90crx
Dec 20, 2011 03:38 PM
sanman000719
Apr 1, 2010 08:16 PM
poorboy44
May 6, 2008 05:20 PM
gilou bilou
Nov 11, 2005 09:05 AM
gilou bilou
Nov 10, 2005 02:06 PM
