RSX springs on EP3 shocks?
......all 02-04 dc5 springs will fit an ep....the base model springs will also fit through 2006. The type-s 05-06 ft springs will will not fit but the rears will. The ft springs on the type-s 05-06 are wound in the other direction so they will not fit in the purches. Honda did this because they found having springs wound in the oppiset direction helped steering imput under full gas....the fg and fa civics have spring wound the same way as the later type-s....as for stance, the ep will be a little higher as it weigns less than the dc5.
I have the RSX Eibach pro kit springs with Tokico d-specs on my ep3. The front dropped an inch like it was supposed to, but the rear didn't really change much. I believe that has to do with the RSX having more weight in the rear. I have a pic or two by tomorrow.
my tire size is 205/45/17 you can use a tire size calc to determine what the wheel gap will be with your wheels.
It's a small drop with the pro kit springs, but not even. The front is slightly lower than than the rear. I'm going to use a 215/45/17 or 225/45/17 in the rear to even out the wheel gap. If you only want a small drop but an increase in performance these work great.
Sorry the pics aren't great, I shot these really quick before i left for work.
mustclime any chance you can post pics of your stance/wheel gap?
i've been around clubep3 hondatech ephatch
pondering what suspens i should put into my ep3
progress/aspec
is what im in between...
it'd help a lot if i had a visual to what the aspec looks like
progress/aspec
all the info you need within this thread
http://www.ephatch.com/forum/showthr...pension-on-ep3
I just got my tracking number for my springs. Where did you purchase the front strut kit? Honda dealer I'm assuming.And what did you end up paying, If you dont mind?
Thank you,
Rick
(you can read it in the thread on ephatch i was posting on there)
no pictures mustclime? =[
