D16Y8 Clutch Problem
So I installed a new clutch in a D16Y8, everything was fine.
I backed it out my driveway, put it in first, drove normally, shifted to second then I punched the gas a little and the car didnt move after that. I could put it in any gear and when i let the clutch out it dosent go anywhere. Dosent stall, just idles as if it's in neutral, and the mph go up.
Today i took it apart again, reassembled everything again, and it is still doing the same thing.
Can something be broken internally in the transmission ?
By the way master and slave cylinders are new and i bled the system several times, clutch is somewhat soft.
I need help asap pls ! I want to get this car back to the customer asap !
ride5150
Jul 12, 2010 11:29 AM
