96 Type R motor swap .. Need some help
Old Feb 12, 2011 | 04:36 PM
DC2R96's Avatar
Default 96 Type R motor swap .. Need some help
I'm putting my old wiring harness on the Type R motor ... I had an OBD1 B18B .. and the distributor plugs don't match up on the new motor .. Can I use my old LS B18B OBD1 distributor on my Type R
Alright I found a diagram on how to wire the old plug to the new plug .. thanxs for the replys
I got another question, on my old engine i had a sensor on the right side of the intake plenium hooked to a vacum line .. the new engine doesn't seem to have this sensor .. any problem there .. do I just not use that plug or do I need to mount that sensor so I can use it with the new motor?
Old Feb 12, 2011 | 04:48 PM
ekcoupeh22's Avatar
Default Re: 96 Type R motor swap .. Need some help
im pretty sure you cant use and ls distributor on a vtec motor
Old Feb 12, 2011 | 06:49 PM
DCRB's Avatar
just swap the dizzy plug from the type r harness to your stock harness
Old Feb 12, 2011 | 07:33 PM
909Dc2Racer's Avatar
if u use ur ls dizzy u have 2 cut off an ear from the dizzy
Old Feb 13, 2011 | 01:12 PM
DC2R96's Avatar
yea .. do you just match up the color wires ??? isn't there 9 wires on the OBD1 and 10 on the OBD2a (the type r motor) .. what would the extra wire be?
viciousvisionslarry
May 25, 2012 09:45 AM
illestpnoy
Feb 15, 2010 07:43 PM
Lee_eg6si
Welding / Fabrication
Sep 22, 2007 07:22 PM
onekoop
Dec 5, 2004 03:26 PM
JDMCivicEF9
Mar 25, 2003 04:20 PM
