quick wire tuck "yes/no" question
i have a quick question
will changing wire length cause any undesired problems with the way the car runs
example if i shortened the cabin harness to make it as minimal as possible with all the fuse boxes and ecu in one location rather than in multiple places under the dash....
ive searched and really all i need to know is yes or no if anyone wants to elaborate on their answer im fine with that as well...
Only thing you really wan't to avoid is lengthening wires, especially those that run to sensors. The extra length increases the amount of noise the wire will radiate/recieve and can throw sensor readings out. Another consideration is the added resistance which may effect sensors.
But shortening a wire in most cases will have no effect.
did the cab and engine bay harness on my 89 dx, aint had no problems, a complete circuit, is a complete circuit, but jus gota make sure you got good ground and power
thanks for all the help
i dont plan on lenthening any wires.. just shortening them so i just gotta make sure not to mess with sensor wires and i should be fine
