Tilton hydralic releaseberings fits on CM twin disckit?
Old Feb 12, 2011 | 01:19 PM
Wanchai's Avatar
Default Tilton hydralic releaseberings fits on CM twin disckit?
I've have search without any result.
Can i use tilton stuff on my Cm twin disc clutchkit?
Thanks in advance
Old Feb 12, 2011 | 07:28 PM
QUICK8CIVIC's Avatar
Default Re: Tilton hydralic releaseberings fits on CM twin disckit?
Thanks in advance
You have to check the contact point diameter of your CM clutch cover diaphragm vs the diameter of the Tilton release bearings you're going to get to insure proper pedal pressure once installed.
Old Feb 13, 2011 | 10:55 PM
Pro-Am 1934's Avatar
Yeah you need to measure your clutch. There are 2 different hydraulic release bearings that Tilton has. They were both made to work with their clutches to make them more attractive to potential buyers. But with that said they may work with other twin disk set ups as well.
The measurements are done from the crank mating surface to the diaphram on the pressure plate. If you do not know yours, call CM and ask for that measurement.
The Tilton carbon/metallic is 2.01", and the Tilton carbon/carbon is 2.08" Also they are 44mm round, so you want to measure the diaphram. Otherwise the bearing could drop right in.
Jason
Old Feb 14, 2011 | 04:28 AM
Wanchai's Avatar
Thanks guys,i will check it out.
Old Feb 14, 2011 | 05:22 AM
The sweed's Avatar
sence tilton states that their clutches works with stock relese bearings i cant see why it wont be a drop in with other clutches that works with stock relesebearings.
Old Feb 18, 2011 | 04:36 AM
we are talking about Tilton Release bearings on a CM clutch not Tilton clutches on stock release bearings..
Old Feb 18, 2011 | 06:51 AM
TDI-North's Avatar
lol ^^, yeah but if the clutches are made to work with stock release bearings, and the hydro release bearings are meant to work with that clutch.... not clicking?
OP just measure them up, it 'should' be ok though.
Old Feb 18, 2011 | 11:14 AM
fast is fun's Avatar
I have one with liberty bellhousing & a clutch masters fx 700 twin and it works
Old Feb 24, 2011 | 06:53 AM
MR.johnson's Avatar
in for more info. broke a fork last year with my twin.
Touge Tuning
Aug 21, 2006 02:45 PM
tofuR
Jun 17, 2006 08:35 PM
ghettoracer
Feb 23, 2005 06:53 PM
NobodysHero
May 6, 2004 12:50 AM
SpeedDreamz.com
Nov 25, 2003 09:23 AM
