1997 HONDA CIVIC LX (Won't Start!)
Old Feb 12, 2011 | 12:03 PM
Philippines03j's Avatar
Default 1997 HONDA CIVIC LX (Won't Start!)
Hi,
I have a 1997 civic lx that will not start. It has been in the 20's here. I have not had any problems with it resently. I drove it at night and parked it. In the morning it wouldn't start. Never had trouble starting before. I am checking the main relay, and distributor (ignition coil and ignition control module). The car cranks and it just keeps cranking and will not start. I changed the battery and hear the fuel pump when turning the car on (2 sec hum). Any ideas?
Old Feb 12, 2011 | 12:07 PM
Former User's Avatar
Default Re: 1997 HONDA CIVIC LX (Won't Start!)
Click the Spark link in my signature. Is there bright white spark at all 4 spark plugs?
Any CEL codes?
Old Feb 12, 2011 | 12:09 PM
Sorry forgot to mention... I am not getting any spark from the spark plugs or distributor... I tried using a ground and I got nothing.
Old Feb 12, 2011 | 02:08 PM
Does the Blk/Yel wire attached to the coil have battery voltage? Have you verified that the timing belt is not snapped? If you answered yes to both, then resistance test the coil and have the ICM tested at an auto parts store.
Old Aug 23, 2021 | 11:21 PM
Eric40Christoph's Avatar
Any CEL codes?
I ha e a orange from all spark plugs
Old Aug 24, 2021 | 08:26 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Ten year bump... you likely have a bad coil.
72 nova
10
Jan 14, 2023 01:34 PM
joyrider58
Jan 1, 2009 10:23 PM
dan89crxsi
Feb 10, 2007 02:44 PM
