help, put in new Hub assembly, now Camber problems
Old Feb 12, 2011 | 10:42 AM
dth0ng69's Avatar
Default help, put in new Hub assembly, now Camber problems
Okay So I thought my front passenger wheel bearing was bad because there was some play with my wheel when i lifted the car. I bought a whole another hub assembley, and threw that on.
after installing the new hub I realized it wasnt my wheel bearing but it was really just my Lower control arm bushing.
heres a pic of what i installed
After installing it My camber was so bad to the point where I cant turn left all the way because of the tires rub the inside of the chassis really bad.
I mean i can drive with it but parking with really bad camber sucks.
Here is my question, since you can't adjust the camber w/o a camber kit I assume that the Hub assembly that I installed was bent? because If i were to take it to get an allignment all they would adjust is the toe, and i adjusted my toe already and my allginment is fine its just the camber is reallly bad. Do you guys think that the Hub assembly is bent? or I need a camber kit?
Please help!
dhonda
May 15, 2011 03:50 PM
UrbanAdolescent
Suspension & Brakes
31
Sep 8, 2010 07:16 AM
4serioferio
22
Mar 14, 2009 08:22 PM
DarkTeg94
Nov 24, 2004 07:23 AM
d8168055
Nov 29, 2002 08:41 AM
