Low idle, sputtering,& burning oil HELP!
Old Feb 12, 2011 | 03:57 AM
SaWaHLUVSherCRX's Avatar
Icon2 Low idle, sputtering,& burning oil HELP!
I just got this crx 2 weeks ago and with all this snow havent gotten a great look at it! i was told dont go over 80 (high rpms) but last night i started hearing the engine knock, tab, sputter not sure the right word but the car shakes!! I was going the most 75 mph and now idle is low low and i sound like a lawn mower, I pulled over and no oil on stick. I put 3 quarts filled to a bit over.. so not sure how that works with it being dry... newho that didnt stop it too much.. now i know about my rex: origanial motor d15(its a hf) but it has a si tranny and no muffler from catalatic converter. supposely everything replaced, and the air intake box is gone... does anyone know what all i shoud check first... im outta town n totally scared i wont make it back home if i keep this way. any other questions u need ask ill try my best!!
Old Feb 12, 2011 | 04:10 AM
ef92b's Avatar
Default Re: Low idle, sputtering,& burning oil HELP!
well.. start with the basics.
check all fluids. engine oil, gear/tranny oil, brake fluid
check ignition system and replace parts as necessary. new spark plugs, clean dizzy rotor and cap. if not, replace them.
replace/install air and fuel filter.
check fuel level
check charging system. replace battery if necessary. clean all grounding wires using sand paper or wire brush.
check for oil/fuel/fluid leaks
...that's all i can think of right now
Old Feb 12, 2011 | 06:37 AM
KINGVEM^^ED6's Avatar
yeah g pretty much do a tune up
i wouldnt.recomend driving.it till you know theproblem
last thing u want is ur lil hf.left on the street for god knows who
Old Feb 12, 2011 | 09:00 AM
i replaced spark plugs and 2nd cyn.. gross!! but still doing it... i was told regasket valves and orings... nething else to think of doing???
Old Feb 15, 2011 | 06:11 PM
honintegra's Avatar
sounds to me like u have some ignition problems. you should really check your dizzy, cap and bug also plug wires. are the plug wires old? if the ears in the cap are worn down or the bug is worn it will cause the car to miss and sputter. also sarah if the valve seals are that bad it would be smoking like a train! so start with ignition.
Old Feb 15, 2011 | 10:14 PM
RTUNED BUILT's Avatar
well if u still hear the knock on the engine after adding oil u might of spun a main bearing.. before u start replacing more parts on youre engine and guessing what can it be do a compression test, that should tell you alot on how youre engine is performing. cant be an ignition problem cause you would have trouble keeping the car on at all times.
jonyi27
Dec 28, 2012 11:43 AM
Sassafrass
Dec 4, 2006 05:50 PM
frog37_
Feb 15, 2006 11:34 AM
el3vate
Oct 5, 2004 09:11 PM
freeplay
Sep 13, 2003 02:16 PM
