GSR Cluster
Old Feb 12, 2011 | 12:03 AM
munchies91crx's Avatar
Default GSR Cluster
alright im about to buy a 95 gsr cluster n i was wondering with the swap do i have to go to a electronic vss to make everything work right? can i leave it like it is and have everything work? if so how. thanks guys
Old Feb 12, 2011 | 12:18 AM
hammergunner's Avatar
Default Re: GSR Cluster
yes you need a electronic vss sensor to get it working
Old Feb 12, 2011 | 08:37 AM
how do u run an electronic vss to a cable tranny?
Old Feb 12, 2011 | 08:38 AM
efjones9's Avatar
Its pretty easy to install the eletronic vss. I used a 92 civic vss. U will need to modify it to fit
Old Feb 12, 2011 | 08:41 AM
jones could u help me with it?
Old Feb 13, 2011 | 12:17 AM
you also need to run the wires from the vss to the ecu and then to the gauges
jacksonww
May 4, 2009 10:41 PM
boyee1
10
Dec 15, 2007 10:07 AM
n1neb4ll
Jan 25, 2004 01:05 PM
B20zvtecek
Nov 20, 2002 06:30 AM
juicy.koreans.suck
13
Nov 13, 2002 06:40 AM
