cd5 accord parts and h22a IM and Cams and
My name is Peter. Live in Orlando. Have a bunch of good parts from my 94 accord EX coupe 5 speed. I removed all of these parts to make a more performance oriented car with an H22A and a bunch of Skunk stuff. I am right in the middle of three different things with it now. First one is the painting of engine compartment, next is rewiring engine harness for a tuck, suspension mods.
None of these parts are junk, they are all working order parts that were removed for special purposes. Not because they were faulty. So my garage is full. I will send you a Picture or let you come see any items right away.
Peter 407-921-4700 NO TEXTS, just live talking people.
IM's from H22a
Fuel rail from F22b
H22A valve cover
330cc H22A fuel injectors
H22A cams and cam gears
H22A harmonic balancer x 2
ABS main unit and computer and other aspects like wiring.
SRS Driver side and Passenger side airbags
OEM Steering wheel black
All SRS parts including yellow wire harness with sensors and cable reel, computer etc... all of it. These items work great.
Complete A/C system works great. Compressor, relays, drier, condensor, all lines, interior parts under dash, If I did not list it, I still have it, this could be a great deal for someone.
Complete Power Steering system, cooling line, resevoir, pump, lines, Bracket etc. Works perfectly.
Throttle bodies about two or three of them.
Some sensors like tps and so on
F22 axles left and right and intermediate. Needs boots on one axle.
Headlights not too old, a little cloudy but ready to run immediately.
Brake Booster and Master Cylinder and prop valve.
IM's from H22a
Fuel rail from F22b
H22A valve cover
