1994 honda accord ex
so im thinking about putting a h22 motor in my accord, and i heard that it should bolt right up no problems. is that true. and i was wondering if i have to change wiring or the f22 wiring will also work. and i do i have to change the pcm to the h22? thanks
Yes it will bolt up with correct motor mounts. Do yourself a favor and get the hasport mounts for the swap. The wiring will need some adjustment. U will need to extend some plugs. And add a couple plugs.
i just did this swap this weekend, just do a search here as well as google, there is a ton of info about doing this swap. That being said, i encountered some "issues" not discussed in any of them. I will be doing a write up of my swap soon. It is a pretty easy swap to do all in all, the wiring is not real bad if you know what you are doing, and u will not have to change to obd1 which will be helpful as well.
Yes, you'll need the correct ECU. You can go with:
*H22's factory JDM P13 ECU - You'll need to wire up IABs & Knock Sensor(KS).
*P28 chip ECU(H22 Basemap) - No need to wire up KS nor IABs.
*P72 chip ECU(H22 Basemap) - You'll need to wire/use IABs, & KS
ye you can swap the motor but you have to do the perfect swap on the motor with harness and i think that you have to change the pcm for the motor to runs fine
