Crimson Linea Sport torque specs?
Old Feb 11, 2011 | 08:27 AM
Captain Key!s's Avatar
Default Crimson Linea Sport torque specs?
I am going to refinish my wheels and I have found a ton of torque specs for BBS RS lip bolts, but nothing for other companies. I wanted to assume that the specs would be the same, but the info that I found differs from size, model, etc. Is there a "universal" torque spec that I can put these together with?
Old Feb 11, 2011 | 08:39 AM
toyomatt84's Avatar
Sanji
Default Re: Crimson Linea Sport torque specs?
35 lb/ft is a good number to go with for multi-piece wheels in general.
Old Feb 11, 2011 | 09:02 AM
That high is ok? The RS specs that I read were in the 22-25 range. I just don't want to snap a bolt. I figure you know better than most, heh.
Old Feb 11, 2011 | 11:14 AM
toyomatt84's Avatar
Sanji
If you snap a bolt with 35 lb/ft, the bolt is definitely too weak for the purpose of holding your wheels together. Most hardware used on wheels should be hardened to the point where 75 lb/ft wouldn't even cause them to distort.
Old Feb 11, 2011 | 12:31 PM
Good info, thanks sir. Never put wheels together...looking forward to it.
ray.riddler92
Jul 27, 2011 05:07 PM
mikehannam
Apr 7, 2009 07:22 PM
EG-SIXV-TEC
10
Apr 2, 2009 07:43 PM
iRockTheDA9
Aug 5, 2008 02:16 PM
2k1TypeR0610
Nov 1, 2001 02:38 PM
