white smoke from my radiator?
Old Feb 10, 2011 | 07:27 PM
hmongxcuz's Avatar
Default white smoke from my radiator?
my radiator has smoke coming from all around it after i drive. then stops when i park it.
my raidaitor looks beat up, could that be the problem?
b16 eg coupe. new headgasket
Old Feb 10, 2011 | 07:36 PM
shietzitzkien's Avatar
Default Re: white smoke from my radiator?
check all your hoses. you might have a leak somewhere.
check your coolant levels also.
Old Feb 10, 2011 | 09:07 PM
netfreak's Avatar
If it's just steam and no fluid leaking on the ground, replace the cap. If no change, take the rad to be pressure tested.
Old Feb 11, 2011 | 05:57 AM
fcm's Avatar
fcm
Old Fart
Most likely the rad top cap is leaking, fairly common on older Honda/Acura stock rads, and as mentioned it is steam not smoke. 94
Where in Kelowna are you netfreak?
Old Feb 11, 2011 | 08:32 AM
netfreak's Avatar
Originally Posted by fcm
Most likely the rad top cap is leaking, fairly common on older on older Honda/Acura stock rads, and as mentioned it is steam not smoke. 94
Yeah I had to replace the cap the first day of owning my CRX as steam was coming out the hood
I live and work in the glenmore area, and I'm at pick-n-pull every second weekend
Old Feb 11, 2011 | 11:01 AM
fcm's Avatar
fcm
Old Fart
Will be at PicknPull this weekend, there is a 96 Integra just put on the lot, will see if there is anything left worth pulling.
BTW I am out in Rutland and work at Air Wolfe Auto Air behind Budget rent a car on 97.
Old Feb 11, 2011 | 11:40 AM
netfreak's Avatar
Ah yeah I saw that one on the inventory list. Luckily I grabbed what I needed from the last couple 95-96's and the SiR that was in there. I work in the industrial area of glenmore off sexsmith road. Power filtering, battery backups, etc etc
cesrflores93
Honda Civic (2001 - 2005)
Mar 25, 2016 02:07 PM
chiliredDX
Aug 4, 2006 12:40 PM
kublai
May 22, 2005 08:30 PM
1 POINT 8
Mar 24, 2004 04:39 PM
Happyman
Dec 11, 2003 08:38 AM
