i need help: car starts and then dies
car starts and dies right away?its a b18 turbo with fresh 9:1 deck cp forged pistons 67trimm turbo runnin on aem stadalone...i had sum problems last fall gettn it to run rite..it was the head but then oil issues came about and the motor locked up at IDLE and nothing was broke...now it starts runs a couple seconds and dies....i was hoping some 1 would have sum info...
ok anyway have you pulled the plugs? did you try doing a compression test? also your idle screw may be set two low
