Electrical Problem
Old Feb 10, 2011 | 04:01 PM
palazuelosva's Avatar
Default Electrical Problem
I have a 96 honda civic DX coupe, the cluster, turning signals and hazards some times work and some times dnt. I know its not the cluster cuz I already replaced it and the problem persists. The turning signals and hazards also fail to work from the outside. The head lights fliker from time to time and some times turn off completely.
Old Feb 10, 2011 | 04:07 PM
00siboy's Avatar
Default Re: Electrical Problem
Have you checked fuses/relays? Also could be turn signal switch. Are the gauges working ok since the replacement? Maybe just quickly check for damaged wires for headlights.
Old Feb 10, 2011 | 04:12 PM
Former User's Avatar
When you say cluster, do you mean the gauges, back lights, or warning lights?
Make your descriptions as specific as possible.
Old Feb 11, 2011 | 05:52 PM
When I say cluster I mean everything the backlight the gauges, the cluster is dead and only comes on when it wants to. However the hazards always work even if the cluster is dead. The outside turn signals only work when they want to. The ecu isn't under the dash on the passanger side, any idea where else it can be?
Old Feb 11, 2011 | 05:53 PM
I know when the cluster is working because my check engine and SRS lights r always on due to no O2 sensor and no airbags.
Old Feb 12, 2011 | 05:31 AM
si_cloud's Avatar
ok none of my lights are working on the outside except the headlights on my 00 si wtf could it be????????? ne body have any clue???????
Old Feb 12, 2011 | 05:41 AM
grumblemarc's Avatar
The Grumpiest
Start your own thread.
Old Feb 12, 2011 | 05:48 AM
92slamed4door's Avatar
check ur fuses
Old Feb 12, 2011 | 06:02 AM
OP, was this car stolen and the dash was trashed?
1) Pull the hazard lights switch out of the dash and check whether its connector is not fully seated. Also inspect the connector and switch terminals for damage.
2) Do the same for the cluster connectors and combination light switch connectors.
Old Mar 6, 2011 | 10:18 PM
Yes the car was stolen and the dash was replaced. I found a cable under the dash that was ripped I just wired knot it and it worked.
Old Mar 7, 2011 | 06:17 AM
Black Diamond's Avatar
Thats your problem right there you have some loose connections, try to get back to those wires and solder them up.
tommybarrett
Jul 18, 2010 04:57 PM
NazVil86
Aug 4, 2009 02:45 PM
furiousbob
Dec 14, 2008 11:46 PM
lluks_844
Jun 1, 2007 05:01 PM
crexer
Apr 4, 2004 08:29 AM
