crx with a type r?>.....
Old Sep 25, 2002 | 09:51 AM
crx-w-b18c5's Avatar
Default crx with a type r?>.....
does any one know what the work is that is involved with swapping a type r into a crx, i look everywhere and cant find a person actually talk about the work it took for them to swap that engine if anyone knows thanx
Old Sep 25, 2002 | 10:10 AM
9KRacer's Avatar
New User
Default Re: crx with a type r?>..... (crx-w-b18c5)
You need B-series mount kit (HASport), a wiring harness, and a conversion kit to go from cable to hydraulic operated clutch. As far as wiring,the speedometer goes, I am not sure. The CRX is cable driven the R is not. But to get it running and bolted in, you need all the above. It can be done. Its all a matter of how.
Old Sep 25, 2002 | 04:24 PM
bryant's Avatar
Default Re: crx with a type r?>..... (9KRacer)
why not just get a cable tranny and bolt it up to the ITR motor. Many problems solved.
Old Sep 26, 2002 | 01:37 AM
SMSP's Avatar
IM Tbone, he did it in a 2nd gen CRX
Old Sep 26, 2002 | 06:35 AM
Sleeper Sii's Avatar
I hear the cable to hydro conversion fo the tranny is tricky and expensive.
Why not put type R cams and pistons in a B16 / B18 ? Might be cheaper.
Old Sep 26, 2002 | 11:46 AM
blackturtle916's Avatar
Default Re: crx with a type r?>..... (Sleeper Sii)
the tranny part isnt as tricky as the OBD 2 to OBD 0 conversion...........IM TBONE....got any pix of your rex? or a site that tells how you did it? i am going to do this swap on my GF's rex and i would rather do it all myself then take it to some shop who will charge me a shitload to do the wiring..........
Old Sep 25, 2010 | 12:50 PM
bigred850's Avatar
I'm about to purchase a crx w/b18c5 motor and a b16 tranny. He said the speedometer is not hooked up. What connection needs to be wired to the cluster? Will the VSS to instrument cluster connection make any difference in the way the motor and tranny functions? I'm thinking it won't make any difference once the VSS is connected to the cluster except I will be able to tell how fast I am going.
flatblack-h22
Jun 18, 2012 08:36 AM
haroldthefly91crx
Sep 4, 2007 09:39 PM
beef-cake
13
Apr 22, 2007 03:41 PM
nitroice40
Nov 2, 2005 03:30 PM
Mazmay
Apr 5, 2002 08:10 PM
