jdm b18b dizzy question
I am having problems getting my crx to run right. The dizzy that's on there has broken teeth for the cam position sensor. My question is can I use an obd0 dizzy from another non vtec b18 like 90-93 ls or does it have to be from the b18b?
OBD is on board diagnostics
1991 and prior is OBD0
92-95 is obdI
96-98 is OBDIIA
99+ is OBDIIB
The B18B comes in OBDI OBDIIA and OBDIIB setups, all with different plugs, but the same internally
As to wht motor you have, find out the year, it's pretty simple, plus what year is your car
92-95 is obdI
96-98 is OBDIIA
99+ is OBDIIB
It it has the round milky white connector, the car is still running OBD0. You wouldn't need a jumper harness for this
Wow, i have a;ready given you the answer already, why is it so difficult??
