h22 to f22b
It should have two different ecm's in it, one's your computer to the engine and the other is to the tranny so you can use a automatic computer in a manual as long as you have a manual tranny ecm. But as for the H22 to F22 swap you should have no problem doing it. I have a 95 that came with a H22 V-tech and I am putting in a F22A. Only thing is you'll have a few plugins for v-tech and knock sensor that won't hook up to the F22A. I am still working at installing my F22A into mine so if I run into some issues that you would too I'll shoot you a PM. Hope this helps.
From what I've read on other threads there might be a lineup problem with your driver side mount, again don't remember well. I think a driver side mount from a 90-93 Accord will be sufficient though. Good luck with your project!
jasonyap
Sep 28, 2005 09:30 AM
