Swap questions?
Old Feb 9, 2011 | 04:00 PM
BlendedEM1's Avatar
Default Swap questions?
Hi I just got a 91 civic SI hatch and it has a blown head gasket and I want to swap it with a ZC d-series or maybe a B-series but I have been trying to find out what is needed for the swap seeing as how I haven't done a swap before detailed instructions would be help full or at least point me in the right direction thank you for your time.
Old Feb 9, 2011 | 04:06 PM
rd91sib18c5r's Avatar
Default Re: Swap questions?
A ls swap would be real easy just need the mounts, the harnes plugs right in.
You should be able to do it under 1k.
Old Feb 9, 2011 | 04:45 PM
BlendedEM1's Avatar
Yes it is obd0 also another question I have is what is the transmission type in my car cable or hydro and what is the difference between the two, and do the b series axles fit in the hubs with out any problems
Old Feb 9, 2011 | 04:59 PM
stackedhouse's Avatar
Yes the axles will fit there tight but fit... Yours is cable.. The 92 and newer is hydro search up the differences but you'll want cable to
Make your swap easier or a hasport hydro conversion
Old Feb 9, 2011 | 05:19 PM
BlendedEM1's Avatar
ok cool thank you guys i'm sure I will have more questions thanks again got to love the Honda community
Old Feb 10, 2011 | 12:25 AM
hatchet_honda's Avatar
you will also need an intermediate shaft from a 90-93 integra. and the dust ring on the si knuckle will have to be removed. otherwise your axles will bind and not rotate properly. its a metal ring on the backside where the axle slides in
Old Feb 10, 2011 | 08:07 AM
redef90si's Avatar
i Have the B series swap mounts you need $120 obo shipped,Matt
link:
http://hondamarketplace.com/showthread.php?t=2892509
captainrichwine
Sep 1, 2010 09:29 PM
Blackgvr4
14
Mar 3, 2009 05:25 AM
slammedej1
Mar 7, 2006 08:52 PM
GearDownCRX
14
Jan 6, 2005 03:17 PM
IwantAswap
Jul 16, 2003 09:57 PM
