90 civic dx with a b18b1
ok i have a 90 civic hatchback dx auto and i swapped a b18b1 with a 0bd0 integra 5spd harness and ecu but i did not do the wiring for mp fuel injection yet but what i was wondering isnt the car still supposed to turn over? thnx
ok i got it to turn over with that harness just had to run the two wire black/white and black/yellow but now i need to do the wiring for dp to mp but i think i figured out the injectors i just need help with the distributor wiring and sensors
To help you out use the engine harness for your car everything plugs in beside a few plugs. Then you add the wires for the fuel injectors and dizzy and your done. Also wat obd ecu and dizzy and injectors do you have??
I am doing a similar swap putting a B18B1 into a 90 CRX SI OBD-0. I have everything and the swap is almost complete but this is the first I've heard of needing a resistor box for the injectors because i'm using b16a injectors that are recommended by quite a few people. Could you shed some light on this for me please?
lrcrx90
May 29, 2006 08:14 PM
LSvtechatch97
Oct 15, 2004 04:30 AM
Roadracejunkie
Sep 27, 2004 06:09 PM
