transmission filter
Old Feb 9, 2011 | 12:35 PM
mykiraa's Avatar
Icon6 transmission filter
I have a 1998 honda accord lx 4cyl and i need a transmission filter. Are the transmission filters serviceable and if not what do you recommend? Please Help!!!!
Old Feb 9, 2011 | 12:52 PM
nicolaselias's Avatar
Loved
Community Favorite
Default Re: transmission filter
To get to the transmission filter, you have to disassemble the entire transmission...
If you already have the transmission down, then its good to change it...
If not, what I recommend is a 3/8" Magnefine In-Line transmission filter
http://cgi.ebay.com/ebaymotors/Magne...Q5fAccessories
I have it on two of my cars and its truly something excellent...
Old Feb 9, 2011 | 08:45 PM
19Accord97's Avatar
Yup, they are pretty much considered "non-serviceable" due to what nicolaselias said.
I would use the product he recommended as they do work well. I plan on getting one of those and a tranny cooler sometime!
However, how has your transmission been maintained? Generally, most people follow the 3 drain/refill method. Drain your transmission fluid, refill, and drive 50-100 miles and repeat 2 or 3 times. With that being said, ONLY use Honda transmission fluid.
Old Feb 10, 2011 | 11:01 AM
shortlid's Avatar
Ya inline filters are a good idea on Honda automatics since they don't have a pan to drop.
Old Feb 13, 2011 | 05:45 AM
mykiraa's Avatar
nicholaselias, if i get that put on will that help the transmission fluid to flow through to the transmission. Are those easy to put on and how do you put it on?
Old Feb 13, 2011 | 11:16 AM
Loved
Community Favorite
They are super easy to put on..
You cut the rubber transmission line, and the filter literally slides onto the line, then you clamp the two ends with metal hose clamps... Then your done!
When last did you change transmission fluid? You may want to do that as well if you havent in a while..
Old Oct 10, 2011 | 03:17 PM
Steve Z's Avatar
It's not going to fix the jerking problem you describe in your other post.
Old Mar 12, 2020 | 04:42 PM
ThriftShopBuddy's Avatar
The jerking problem is caused by the middle screen in the torque converter control solenoid being clogged with the trash from the bottom of the transmission fluid reservoir.
Old Mar 13, 2020 | 04:10 AM
If you remove it make sure you have a new gasket handy.
the soL that could
Jun 18, 2010 04:42 PM
niptek
Honda S2000
Jan 11, 2010 06:05 AM
cb900f2
Jun 29, 2007 02:52 AM
Overmind22
Mar 28, 2004 09:47 AM
UncleRay
Feb 1, 2003 06:04 PM
