Back-up fuse blows
95 4dr lx. I asked later for the fuse panel diagram but forget that guys. Found the problem. I found the back up light fuse blown. When I replaced it with another and started the car the fuse blew again. What can be causing this problem by any chance?
I thought the back-up light fuse idnt really have to only do with the back up light but with other things as well?
Quote:
Just so you guy's know the "back up" fuse is NOT for the lights, It is a constant power fuse which holds your radio memory and numerous other functions
Found the problem guys. As stated before the back-up light fuse kept blowing. I was told to check the reverse light circuitry but couldnt find anything. So I purposely put in aout 2 or 3 more fuses to cause a short so that maybe I can see it. As i suspected I finally saw smoke. The fuse blew and smelt the smoke and started looking for it all over the car. Finally I noticed the hood smoking and poped it to find a small flame under the hood. Turns out the VSS caughtg onn fire. Thats where the short was. I did not know that was connected to the fuse until I read the manual and found VSS to fuse slot 1. Go figure, my luck. Luckily I had another VSS sitting around so was able to swap it out, cut the wire back and reconnect it to a good section and put a new fuse in. Eureka it finally works. Everything, reverse lights, power windows, gauges, shifter (auto).
hi i have issues from my back up fuse blown.. i have 1995 civic but my back up fuse blown always.. so in your side how did you do to solve that problem do i need to replace the back up switch or something else.. thanks
If a fuse keeps blowing then somewhere after the fuse the power wire is making direct contact with ground-hence the high current draw.
