On my way to 14's?
Old Sep 25, 2002 | 08:36 AM
reefer_bob's Avatar
Default On my way to 14's?
I'm only hoping for a 14.999 tonight at Sac Raceway...
'00 GSR, 28,xxx miles.
Comptech Ice Box
Comptech Al Flywheel
ACT HDSS
DC Cat Back
No PS Belt
18 deg. timing
No passenger side corner lens.
No interrior, empty fuel tank.
205x40r16 Yoko A520's (pressure TBD)
Neuspeed Sports, Koni Yellows (stiffness TBD)
I'll give it a shot. Last time, I ran a 15.16 @ 93 with full interrior, PS belt, stock clutch/fw, and stock tires at 40 psi. I gotta do better than my 2.3x 60' to have a shot at this.
Comments?
I'll have slips tomorow, or maybe tonight...
Old Sep 25, 2002 | 08:39 AM
AbaZ's Avatar
Default Re: On my way to 14's? (reefer_bob)
Its all in the launch.. I was hitting 14.6's with my girlfriends 94 GSR I/H/E and no belts.. stock tires, and full interior.
Jeff
Old Sep 25, 2002 | 06:36 PM
AussieK24's Avatar
If you can get a 2.2 you'll be there!! Let us know how you go...
Old Sep 25, 2002 | 06:55 PM
stupidfast's Avatar
Default Re: On my way to 14's? (b16a4me)
launch your car at 4500rpms and let it spin the tires all the way through first gear.. if it redlines just let off of the throttle ever so gently and continue through first until your going as fast as you can in first, then dont take your foot off of the gas and tap the clutch and shift to second... do the same when you shift to third.. if you perfect that lauch and power shift you should easily hit 14.7.. no problem.....
Old Sep 25, 2002 | 10:38 PM
reefer_bob's Avatar
Default Re: On my way to 14's? (stupidfast69)
Quick post... my best was a 15.09 at 92.xx with a 2.3x 60' foot.
I'm very disapointed.
More tomorow.
Old Sep 26, 2002 | 01:01 AM
H23 Power's Avatar
you really should be running 14's with that setup, i would think
edit: i just noticed no interior...you should be running 14.5's at about 94-95 mph
[Modified by F23 Power, 4:01 AM 9/26/2002]
Old Sep 26, 2002 | 07:48 AM
reefer_bob's Avatar
Default Re: On my way to 14's? (F23 Power)
Yes, I'm very disapointed to say the least. Here is my best slip:
1 - 2.352
2 - 6.402
3 - 9.765 @ 74.194
4 - 12.650
End 15.090 @ 92.743
Granted, my 60's aren't so good. I should be able to get high 2.2's (30 psi on 205x45r16 Yoko A520's) but still even with a 2.2 that'll only get me to like a 14.9.
I had my Yellows on full stiff. I never had a problem with wheel hop.
I adjusted the valves (thight side of spec) 5k miles ago. I have 28k on the car, I'm gonna put in new plugs, cap, and rotor. I guess I just gotta break down and buy a header. Could that really be my bottleneck at this point?
Old Sep 26, 2002 | 08:06 AM
wuhungsixxx's Avatar
New User
what color was your teg?...i was running out there last night with my CRX...
my best run 14.8@95 w/ 2.4 60ft...
i wish i could a 2.3 like you....2.2 is my goal of course
Old Sep 26, 2002 | 08:10 AM
reefer_bob's Avatar
Default Re: On my way to 14's? (wuhungsixxx)
Milano Red, with gunmetal Rota C-8's. (It was the HELLA clean one, or so I was told by everyone that came up to me. )I was in lane 5, then lane 1 after I broke out. My dial in was a 15.2.
Which CRX was yours?
Old Sep 26, 2002 | 08:28 AM
stupidfast's Avatar
are you guys going to be there on the 5th and 6th of next month for the big race...
Old Sep 26, 2002 | 08:40 AM
reefer_bob's Avatar
Maybe. Not sure. If I go, I'd only spectate. I don't have enough consistancy to run. Plus, I 'd have to get DOT Drag Radials... I don't like racing too much on my streets...
Old Sep 26, 2002 | 08:49 AM
New User
oh yes i remember you car...jdm front right...towards the end of the night as i was leaving i saw you buddies excited after your run...you just came into the lanes i believe...yea you probably seen me... i was the tall *** bald asian guy...hard to miss...your car looks dope!
LSegHatchy
13
Apr 19, 2005 11:44 AM
thunteg
Mar 9, 2004 05:23 PM
dc2inms
Oct 30, 2003 12:25 PM
shant
14
Oct 15, 2003 03:38 PM
Champ R
May 5, 2003 09:08 PM
