Zc help
Old Feb 8, 2011 | 09:27 PM
Lil ZC's Avatar
Default Zc help
Hey everyone! I have a 1989 crx si with a 3rg gen zc swap in it and I'm in need of the engine wiring harness but can't find what one I need. Someone told me one for a d16a6 will work but not sure. Any help will be extremely appriciated, thanks.
Old Feb 8, 2011 | 09:47 PM
lazy14's Avatar
Default Re: Zc help
get a ef si harness, not 2 sure bout zc swaps but thats what it sounds like people are tellin u
Old Feb 8, 2011 | 10:52 PM
REXrunner's Avatar
Default Re: Zc help
I would check in with d-series.org they've got lots of zc info there
Old Feb 8, 2011 | 11:11 PM
Nooch's Avatar
Default Re: Zc help
Search feature works amazingly well, just a heads up.
Old Feb 9, 2011 | 02:20 PM
digitally_remastered's Avatar
Default Re: Zc help
visit thezcr.com, there is tons of info there regarding this setup you have. as for my opinion on this matter, yes the d16a6 engine harness will work. make sure you get one for an 89 crx si. its virtually plug and play. you will either need to re-pin your dizzy side of the harness or buy an adapter harness as the zc dizzy does not house the CPS sensor because its located on the exhaust cam of the engine and the plugs are different to begin with.
Old Feb 9, 2011 | 07:06 PM
~sp33~'s Avatar
EFB055
Default Re: Zc help
Really? For the 3rd gen 'ZC' (d16a1)? or are you talking about the 4th gen ZC (black top single/twin cam).
Old Feb 10, 2011 | 02:48 AM
Default Re: Zc help
they are relatively the exact same engine, only real difference is the mounting point on the drivers side, and the fact that 1 transmission bolt will not line up properly. other than those two small issues, thezcr will still be very resourceful to him. i had a d16a1 in my hatch, just had it mounted up and sitting in there, could never get it to fire, come to find out that there is no compression so i recently just yanked the motor and tossed in a d15b2 which fired up first crank lol.
Old Feb 10, 2011 | 10:42 AM
Lil ZC's Avatar
Default Re: Zc help
yes its a dohc zc. its a 3rd gen. theres a guy in portland that has one for a 1991 civic si. he says it will work all that will be left over is 2 wires and i just run them to the cam sensor?
Old Feb 10, 2011 | 01:13 PM
Default Re: Zc help
correct. they will probably need to be lengthened by like 6 inches or so. if your repining the dizzy then thats cool. if you wish to make it as easy as possible, buy the adapter harness i spoke of. rywire offers it for like 50 bucks, or just check ebay.
Old Feb 10, 2011 | 04:51 PM
eg6h22rhd's Avatar
Default Re: Zc help
Www.zcspeed.com
Old Feb 10, 2011 | 06:09 PM
Lil ZC's Avatar
Default Re: Zc help
So an adapter harness for one plug is $50? If I checked eBay what would I type in?
Old Feb 10, 2011 | 06:28 PM
Default Re: Zc help
http://cgi.ebay.com/ebaymotors/88-91...Q5fAccessories
did the work for ya pal. if the link dont work just type in dohc zc. itll show up.
Old Feb 10, 2011 | 06:29 PM
eg6h22rhd's Avatar
Default Re: Zc help
Go to www.rywire.com
Old Feb 10, 2011 | 06:34 PM
KINGVEM^^ED6's Avatar
Default Re: Zc help
hit up member clipsed im sure he can wire u up something
Old Feb 11, 2011 | 12:27 AM
CRXguy_88's Avatar
Default Re: Zc help
Been there done that
Here ya go End of story...
http://www.google.com/m/url?client=m...TAzk3ir2RqbScg
Redemption
Sep 25, 2009 09:48 AM
The Destroyer
11
Dec 30, 2005 02:22 PM
SC-MK1
May 22, 2005 08:51 PM
vtec_head
May 8, 2002 08:59 AM
vtec_head
May 8, 2002 05:31 AM
