DX with B16a2 Sputtering/missfire HELP GOING CRAZY...
Ok so I bought this B16a2 DX hatch about a week ago, its been running great I washed the engine second day I had it and still ran great till yesterday.. I got in the car star t it up and went to grab a bit was parked for about 2 hours and when I came out it was raining I get in the car and all is well till I get to the first red light and put the car in Neutral, as I did this the RPM's went to almost 0 the light turned green put the car in gear and it just Sputtered all the way from then on. I have a B16a2 with 1998 harness and running a CTR ecu in it. I tried swapping ECU's with chipped P28 and Stock p28 and still does it.. Also checked all plugs and wires all seem well, Car is missfiring aloto and running like Sh*t I have NO CEL's and I have no clue what it could be..Could it be the Dizzy I just bought one so if this could be it lmk so I can put it on or if anyone has came across this please help this is annoying...
I took dizzy cap off and everything seems dry inthere... No codes whatsoever that's why I'm running around trying to see what it could possibly be...
Went to Autozone, bought brand new OEM replacement plugs and started the car and went away car runs like a champ again after 12.99 for each Plug..Thanks for the help guys
12.99?! theyre like 2.50 here. does your check engine light work? sounds like you should have thrown a code there. maybe the p/o pulled it out
Low Ek
Nov 24, 2016 12:02 AM
Royal_C!ty
May 31, 2012 01:31 PM
Slowass2dr
16
May 15, 2006 05:42 AM
