SH lude to base
Old Feb 8, 2011 | 07:19 PM
Rob97'SH's Avatar
Default SH lude to base
Anyone know the knuckle of an SH is the same as the base? I checked out a dealer online. The part # are different . Anyone swapped out the Sh to base setup?
Old Feb 8, 2011 | 09:13 PM
asianpoet's Avatar
Default Re: SH lude to base
yes they are the same.. (pm me, i have question about your block) i have a 99 sh
Old Feb 8, 2011 | 11:53 PM
vinuneuro's Avatar
They aren't the same at all. For one thing the radius rod connects to the knuckle in the SH instead of the lca.
Every single suspension component in the front including the subframes are different between the Base and SH.
Old Feb 9, 2011 | 09:45 AM
Rob97'SH's Avatar
Vinuneuro, your right. I was looking at the picture of the knuckle , very slight difference but the lower control arm and rad arm are way different. you happen to know if I will have any problems with interference with base axles if I keep the SH suspension?
Old Feb 9, 2011 | 02:35 PM
Rosko's Avatar
The base axles will work just fine. I converted my SH to a base a few months ago as well.
Old Feb 11, 2011 | 08:03 AM
RushGiver29's Avatar
From: West Des Moines, Iowa, United States of America
As did i as well, i used the base axles for my setup and i didnt/dont have any problems.
Old Feb 12, 2011 | 02:01 PM
blake903's Avatar
what else do you have to have to delete the atts unit, just axles?
Old Feb 12, 2011 | 05:51 PM
1GPlusSH's Avatar
if you keep the sh block, you'll have to fab up a plate that mounts your intermediate shaft to your block. it's a pain.
Old Feb 12, 2011 | 06:25 PM
blake903's Avatar
that's what i was thinking, i've seen a blueprint of what needs to be made somewhere on the net before but now i cant find it, any idea where this write up is?
Old Feb 12, 2011 | 06:35 PM
1GPlusSH's Avatar
on here somewhere. if you're okay at fabbing up parts, it just takes time. i suck, and it took me about 5 hours...that includes going to a metal yard and getting the metal to fab. i know i've seen it on here after i had done it. i forget what size piece they recommended, but i'd go a little bigger. my first piece was that size, and i broke it while cornering. i went slightly bigger and didn't have any problem. i did a little searching, and "pirate" on here used to make them...maybe you can get in touch with him and get one
Old Feb 12, 2011 | 06:37 PM
1GPlusSH's Avatar
https://honda-tech.com/forums/showth...ighlight=plate
Old Feb 12, 2011 | 06:39 PM
1GPlusSH's Avatar
https://honda-tech.com/forums/honda-prelude-4/type-sh-base-comparison-why-sh-needs-its-own-block-code-%2Apics-inside%2A-1081801/
https://honda-tech.com/forums/honda-prelude-4/mounting-non-atts-tranny-atts-block-%2Asearched%2A-760082/
Old Feb 12, 2011 | 06:55 PM
blake903's Avatar
Thank you very much kind sir
and im going to school to be a mechanical engineer and have access to a pretty nice machine shop at any time so im gonna give it a shot... hopefully i can figure it out
Old Feb 12, 2011 | 07:07 PM
blake903's Avatar
ahh damn.... what im seein is that i have to have a base tranny... has anyone deleted atts and kept the sh tranny because i just built mine, lol i guess i shoulda done some research
Old Feb 12, 2011 | 08:08 PM
1GPlusSH's Avatar
i thought it was in once of those two articles...but i'm not going to check. good luck
Jim W
Mar 24, 2016 05:35 PM
Krenor
Jun 27, 2012 05:12 AM
Vbp6us
Apr 25, 2005 09:46 AM
zer0zer0 TypeR
Sep 27, 2002 05:38 AM
JinMTVT
Feb 1, 2002 07:43 AM
