Arias ACT B18 ITR Integra
Old Feb 8, 2011 | 06:52 PM
ef9sirhatch's Avatar
Default Arias ACT B18 ITR Integra
-b18a1 short block bored out to 84mm freshly honed walls are clean. comes complete with main caps, crankshaft, oil pick up, and oil pan etc... block guard was properly installed machined to fit and pressed in then decked. Good for spare internals no pistons/rods *not sleeved* $100
-Act HD pressure plate comes with 6 puck unsprung act clutch still can be used but recomended to replace disc. replacement disc go for $100-130. works for hydro b-series trannys. looking to get $100
-84mm Arias pistons 9:1 compression good for turbo/ nitrous. low miles needs new rings. $280
-94-01 Black integra cargo cover 8/10 condition little wear marks on the edges better condition then most I seen little dirtty. $30
-94-01 Black integra carpet not usual grey. 8/10 condition some stains but not too noticable needs shampoo due to musty water smell from sitting inside the sheld. comes with only passenger side door sill $80
-Itr 5x114.3 front rotors both sides used but good clean condition most likey wont need resurfacing $30
-Brand new 3 inch spectra filter bought the wrong size red and black color no box $20
-94-01 integra or 92-95 b-series oem mounts passenger and driver side no rear $30
text 408-449-2543 if you have cash in hand and you are serious please don't waste my time I won't waste yours
ef9sirhatch
Northern California (Sales)
Feb 11, 2011 06:00 AM
ef9sirhatch
Feb 8, 2011 09:26 PM
TurboDANDEE
Feb 11, 2004 01:11 PM
