bought a honda - 3rd gear grind and electrical issues
Old Feb 8, 2011 | 06:02 PM
Beto760's Avatar
Icon6 bought a honda - 3rd gear grind and electrical issues
hey so i jus bought a 94 honda civic sedan ex. car has 222000 miles already. heres some of the problems alrdy
1. it grinds going into third unless i shift on low rpms so im guessing im going need a new clutch sooner or later but if u got any more info on that id really appreciate ur time
2. the electronics seem to have issues. the sunroof doesnt work dosnt sound like any power is getting to it so ima check the fuses and see if thats the issue but any more info of what it could be id appreciate it.
3. also the power locks unlock when i flip the switch up but they dont lock when i switch it down so im not too sure what the issue is but its the main issue i would like to fix plus one of the rear door window doesnt go down or up but im guessing thats has to due with the motor that lifts the window up and down.
so these seem to be the problems that i found alrady haveing the car for 2 hours so if u guys/ladies have any info on this issue i would greatly appreciate ur imput so thx for reading this hope to hear ur ideals
Old Feb 8, 2011 | 06:12 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: bought a honda it has issues help plz
Sounds like you did "not" get an inspection
I would highly suggest you get one, as it seems you are new to cars
Old Feb 8, 2011 | 06:16 PM
godluvstegs's Avatar
definitely check all fuses before going on any further
Old Feb 8, 2011 | 06:27 PM
Beto760's Avatar
thx for the info will check does fueses no doubt thank you and as for the first reply appreciate the suggestion to get it inspected most likely i will due this jus so i have an ideal on what i may be facing in the future as for experience in cars i would say im pretty decent in knowing whats what.. this isnt my first honda just like to hear other peoples suggestion and opinions helps me narrow down what i may have to due. thx for ur time appreciate u two for ur imput
Old Feb 8, 2011 | 07:13 PM
92lxsleeper's Avatar
your third gear grind is your syncro / gear assembly going. not the clutch.
Old Feb 9, 2011 | 12:19 PM
Beto760's Avatar
Okay so check into my 3rd gear assemby and im not to sure what u mean about synchro but but ill check into it thx for te info
honda_civic1993
Nov 25, 2012 10:46 AM
Ricey McRicerton
Honda Civic (2006 - 2015)
19
Sep 22, 2010 12:12 PM
speed_demon018
Oct 16, 2009 07:03 AM
p0pe
Nov 24, 2003 02:35 PM
ratherbewalking
Oct 8, 2002 07:08 PM
