Steering issue...
Old Feb 8, 2011 | 05:55 PM
Annihilator's Avatar
Default Steering issue...
Ok so here's the problem. I drive my car ('89 Civic hatchback) and when I leave my house, if the top of the steering wheel is pointing to 12 o'clock (like it's supposed to), I can drive it around, and it will eventually point elsewhere when driving straight (right now, it's pointing at 3 o'clock). I also hear some pretty awful noises from around where the driver feet sit at the firewall.
I'm trying to narrow it down, would this be a steering column issue, or the rack?
For reference, I have replaced all of the following (because it all needed to be replaced):
Lower ball joints, upper control arms/ball joints, wheel bearings, inner and outer tie rods.
I figure it's probably the rack, but is it possible to be the steering column?
Thanks,
- Steven
Old Feb 8, 2011 | 06:17 PM
KINGVEM^^ED6's Avatar
Default Re: Steering issue...
**** ur problee right im guessin its the rack
Old Feb 8, 2011 | 10:04 PM
Tyson's Avatar
adjust the pinion gearbox and check if the rack end bushing needs to be replaced on the passenger side.
search 'rack end bushing' in the FAQ for answers.
also take the cover off the steering column and make sure the pinch bolt to the U joint at the base of the column is tight.
Old Feb 9, 2011 | 12:03 AM
^^thank you so much for the tips. It very well may be the pinch bolt at the u-joint, I hear a sort of spring sound coming from that area when I turn the wheel so maybe that's it. I'll check soon (we're supposedly getting a big snow storm today, so probably not today), and post with results. Thanks again!
Ray0226
Honda S2000
Mar 29, 2017 06:10 PM
buzkilr
May 26, 2011 12:21 PM
DA9_DAD
Oct 3, 2005 06:55 PM
Black R
Jul 29, 2004 02:54 PM
jabroni95gsr
Feb 13, 2003 04:12 AM
