Just replaced the negative battery cable and the l/f seat belt doesnt work!!!!!
Old Feb 8, 2011 | 04:34 PM
geetee74's Avatar
Default Just replaced the negative battery cable and the l/f seat belt doesnt work!!!!!
So guys heres the story.. i broke the Teggy out of the garage today to zip her to the shop for some minor tweaks and an alignment. After sitting outside all day in the cold (-2 degrees with a real feel of -20 brrrrrrrrrr!!!) she wouldnt start. Got into the shop and found it was a crappy negative battery terminal. Replaced the terminal and the left power seat belt didnt work!!! The car was only in the shop for about 20 minutes during the repair. So after looking in Indetifix and Alldata for any info (in which i didnt find) i left. on the way home i stopped a gas station for a few items and it worked briefly after driving for another 10 minutes and making a stop it started working again. finally after a short 5 minute ride back to house and in the garage, it works just fine (for now). So here are my questions:
Could this just be temperature related?
Is there a "relearn" procedure for the belts?
Im leaning away from the relearn procedure because the passenger door never stopped working. (but it was never opened outside in the cold)
Old Feb 8, 2011 | 06:16 PM
fcm's Avatar
fcm
Old Fart
Default Re: Just replaced the negative battery cable and the l/f seat belt doesnt work!!!!! W
You said, "Im leaning away from the relearn procedure because the passenger door never stopped working" does that mean the dome light turned on, [pin switch working] when the pass. door was opened? 94
Old Feb 9, 2011 | 03:20 AM
geetee74's Avatar
the light came on and the belt moved every time. Gonna try it a couple times before work today to see if it still works.
91_scca_prelude
Feb 26, 2009 11:10 AM
miggs70
Jan 4, 2008 01:06 PM
Vagabund07
Jun 17, 2007 08:46 AM
CronusSL2
Oct 13, 2003 07:38 PM
