cbr rr 6 2003 problems
Old Feb 8, 2011 | 11:19 AM
luke_legz's Avatar
Default cbr rr 6 2003 problems
hey al im new needed a good site for all types of help and this looked good for that> 2003 rr new starter motor put in and now it wont run its starts with fully charged battery dies 20 mins later with dead battery now i no these have reg/rec problems will it just be this.
many thanks luke
Old Feb 9, 2011 | 02:52 AM
theedeadmau5's Avatar
Default Re: cbr rr 6 2003 problems
many thanks luke
could be either the r/r or the stator, disconnect the rectifier from the stator and check your resistance between the connectors
Old Feb 9, 2011 | 04:17 AM
1GPlusSH's Avatar
if an autoparts store can check the voltage for the stator like they can for an alternator, that's where you should go if you can't check it yourself.
Old Feb 9, 2011 | 08:14 AM
"A"'s Avatar
"A"
Honda motos are known for blowing up regulator/retifiers... My 2000 VFR800 and 1998 CBR1100XX both had the same problem, that'll be the first place I check.
Once replaced the reg/rec, I'll hook up a voltmeter to the batery and start the bike, let it run around 4000 rpm and check the voltage at the bettery terminals, should be around 13.8 or 14.4v, idle voltage should be atouns 12.8 to 13.2v.
If you have below 12v at idle or 4000 rpm, your stator might be dead.
Old Feb 18, 2011 | 06:59 PM
Nico909's Avatar
If it starts but dies, check your stator, because it should maintain charge...you can check to see by bump starting your bike...if you cant then most likely your stator is shot.
barcaboy
Honda Civic (2001 - 2005)
20
Jan 19, 2016 09:51 AM
g0rd0n
Jan 23, 2006 01:26 PM
jsrusse11
Nov 12, 2005 04:34 PM
daveid001
Feb 13, 2005 03:04 PM
